I told you I would have my build sheet up for you soon . . .
This is it:
-GTM® Stage 1 Cylinder Heads:
-GTM® Stage 0 Shortblock
-GTM® Stage 1 Turbo Camshafts:
-Koyo 53mm Radiator
-Greddy Radiator Cap
-Samco Hoses/Clamps
-ARP Main Studs
-RevUp Oil Pump
-Power Enterprise Engine Gasket
-GTM® ARP 2000 11MM Headstuds
-VQ35DE Main Capseals
-VQ35DE Timing Component Kit
-NGK 1 Step Colder Plugs
Car to arrive soon . . . .
This is it:
Cleaning and inspecting cylinder head
Resurface cylinder head with an RA finish
Radius/5 angle valve job
Pressure testing cylinder head (cylinder head is disassembled completely)
New viton valve stem seals
Ferrea® valve springs
Ferrea® titanium retainers, locators, and keepers
Labor:
Teardown inspection and cleaning of the core
Mag and micro polishing of the crankshaft
Balancing of the rotating assembly
Resurfacing (decking) of the block
Boring and honing of the block (with a torque plate)
Assembly of the short block
Parts:
Wiseco®/GTM® Extreme Duty pistons
Eagle® rods (with their alignment and resizing)
Rear main seal assembly
GTM® Race bearings (OEM bearings available)
ARP® 8740 main studs
Intake: 256 deg (stock 238)
Exhaust: 264 deg (stock 240)
Lift: 0.423” (intake and exhaust)
Overlap: 18 deg (at 0.045” lift) – less than stock
-Koyo 53mm Radiator
-Samco Hoses/Clamps
-ARP Main Studs
-RevUp Oil Pump
